Serious Program Error on Ableton Live
When launching Amplitube 3 with Live 9 Beta, the error below appears. Also, Live will crashed when opening large sets. These particular sets works on Live 8 Beta x64. Please tell me the workarounds for this. This is really annoying since after crashing, I will need to work on the same sets again and again. Thanks.
Ableton Live
 A serious program error has occurred. This application will shut down after this message box is closed. ADefaultWinSystemExceptionHandler::HandleStageOne
OK
Answered By 590495 points N/A #121341
In case you are running the program while your computer is disconnected from the internet, try running it again with an active internet connection and see if it works. If you are using either Windows 7 or Windows 8, I don’t see any problem. AmpliTube 3 supports Windows XP, Windows Vista, Windows 7, and Windows 8.
For Mac users, AmpliTube 3 supports Mac OS X 10.6 Snow Leopard and higher. The application supports both x86 and x64 versions of Microsoft Windows and Mac OS X. Try reinstalling AmpliTube 3. Uninstall it first then click Start, All Programs, Accessories, System Tools, and then select Disk Cleanup. Select drive C and click OK.
Check “Temporary files” and click OK to clean the drive of temporary files. After that, restart your computer. Install AmpliTube 3. If you’ll be working on large sets, make sure you have enough memory to support it. The minimum amount of RAM is 1 GB. And also to avoid any problem especially since you are working on large sets, make sure you don’t open other applications to make most of the resources.
Too many programs running at the same time sometimes cause an application to suddenly crash.
