Problem in installation of softwares
I lately faced a very strange problem when I tried to install an outdated version of CISCO VPN into my PC.
The installation seems to start for a little while, the language options could be seen then it suddenly stopped.
The same happened with update of acrobat reader.
Then I downloaded Fixreader Its installation doesn't work either.
Is there a way to fix this problem.
Answered By 590495 points N/A #82145
Maybe there is an error in the file structure of the hard drive that is why everything stops in the middle of something.
File errors are unavoidable.
Uninstall all the programs that you previously installed that did not finish. If you can’t uninstall it because the installation is incomplete then just leave it for the meantime. Let’s try if a simple disk check can help.
  1. Right-click on drive C and then choose Properties.
  2. Click Tools tab.
  3. Click the Check Now button.
  4. Choose Automatically fix file system errors and then click the Start button. Wait for it to finish then close all the windows.
Install again one of the programs that you are previously trying to install.
If the problem is still the same, consider formatting your hard disk and install Windows again.
There is already an internal problem in the system that can’t be fixed.
