No of visitors who read this post:
196
Category:
Misc Networking
Type:
Question
Author:
Martin espino
I am having a problem configuring the new computers at my workplace which are running on Windows 7 Pro x64. I would like to have these connect to the print server using the pushprinterconnections.exe, with the printers mapped through group policy. Adding the 64-bit driver for the Xerox phase did not help.
The other PCs running on WinXP x32 do not have the same problems and are functioning well. I am wondering if I have to create a new printer and also an AD container and policy in the Print Management. Clearly I am missing something. Hope you can help.
That is how you map the printer again according to your needs. If it still gets the problem then it is time to degrade to 32bit windows.
