Hello everybody,
I got a problem with OBML files. I use Opera Mini mobile browser as the default internet browsing app in my mobile. I save several important pages while I browse them through Opera mini. Opera mini mobile browser saves the page on *.OBML format. It is quite well-off for mobile to recall the pages. But I failed to open these OBML files on my pc. I tried several sort of software to open that OBML formatted files. I searched on internet with the key word “how to open OBML files in pc”. But I did not found any such software to support OBML files.
So, I want to know that, how to support an OBML file in a pc?
I know there must be software which supports OBML files. I am really in need of software that supports OBML.
Thank you all.
Hi Smithkd,
There are several ways to go about your dilemma of being unable to open .obml files from your mobile to your PC. It will require the use of Opera Mini for viewing on your PC. Here is how to start off making it work.
Please take note that the emulation methods described not only allow you to open .obml files, it could also be useful for users using slow internet dial-up connections.
Hello smithkd!
Alright, no worries. for your issue, we just need to download a software that allows you to open OBML files.
Here are two accurate softwares that can open OBML files on a PC:
1. OperaMiniLargeDevice
2. MicroEmulator
Hope this helps. All the best.
Justin T.
Hi Smithkd Opera Basic Markup Language. This file is created by Opera Mini 4.x on the cell phone which have java enabled and JSR-75.
OBML stands for Opera Binary Markup Language and is a feature available to browsers like Opera Mini and others created using the Opera Devices SDK 9.6 which is built on Presto 2.1 rendering engine. Here’s how OBML works. When a browser rendering using OBML requests a webpage from a server, the request is sent to a large, power server farm. The server farm will then retrieves the requested webpage and converts it to OBML format.
The OBML version of the webpage will then be sent to the requesting browsing device and then displays the OBML version of the webpage. You can’t use Google Translate to open the files as what the post above suggests. But on the other hand, there is still a way on how to open those OBML files of yours. To learn the complete procedure, you may visit
Java in the Field | Opera Mini as a PC Browser (big screen)
and
Java in the Field | Using Opera Mini 4.1 Features with OperaMiniLargeDevice 0.6.
Regards
Sharath Reddy
