File cannot be created while opening a window on lotus notes 8.5
Hi TechyV buddies!
Whenever I attach a XL file, I use Lotus8.5. However, I often get an error message which says: “[strong]FILE CANNOT BE CREATED”
In order to solve this problem, I have used killnotes.exe but this is just a temporary solution. I need a permanent solution to my problem if ever I encounter this problem again. Can you help me find a permanent solution to this issue? Thank you!
