Configure the System Clock in Windows 7 Starter
Hello experts,
How to change windows tray world clock? My operating system is windows 7 starter and I need to configure or change the world clock for there is a block out occurred a few hours ago and need to set the time correctly. Can you give me some instruction on how to do it? Thank you.
Best Answer by amy pete
Answered By 0 points N/A #181601
To adjust your computer's clock you just have to follow a few simple steps, first click the Start button, then go to Control Panel, a new window will open click on Clock, Language, and Region, then under Date and Time click on Set the time and date from there you can now adjust your clock and time zone.
Answered By 0 points N/A #181602
Hi Kristen,
Here are the steps to update your tray world clock, this would also allow you to customize the format of itime and date.
  1. Click on the 'start' button
  2. Open 'Control Panel'
  3. select 'Region and Language'
  4. click on 'additional settings', its almost at the bottom of the page
  5. click on the 'date' tab
  6. now, you can customize on how you would want the date and time shows on your desktop.
  7. click on 'apply'
  8. click on 'save'
Hope this helps.
