I need some amazing wallpapers for htc and looking for more and more. Do you have a good source from where I can download free? I need the source full with wallpapers and next buttons to select out my choices. Please help me.
- 57 reads
- 2 comments
Hay, I am attempting to run PLS in SPSS 17.0. I installed the plug-in, Python 2.5 and the module from dev central. I ran the syntax off Import PLS. It all worked well. However when I clicked Analyze-regression-Partial least squares, it still gave me the error message:
Partial least squares regression
The PLS dialog box is an extension procedure that requires the pls Extension Module to be installed.
- 56 reads
- 1 comment
I know that when you block someone of facebook, they will no longer show up in your search history. My question is if you unblock that person, will they start to show up in your search history again?
- 205 reads
- 2 comments
When I am attempting to connect to a Symantec PcAnywhere thin host will be launched within a Lights-out restore session and through a Symantec Recovery Disk error and the PcAnywhere connection fails. The error is listed below is generated.
Symantec pcAnywhere
The selected computer is not responding.
Connection cannot be made
- 103 reads
- 1 comment
Hello. I heard about this Cleartype Font Handwriting. If I am not mistaken in understanding it, you can actually make your own handwriting as the font of your text files. Now, I am really interested in doing this font so I need your help in doing the easy step-by-step in achieving this font. Your help will really be appreciated, thank you in advance!
- 64 reads
- 1 comment
Hi. I have been working with Autodesk Alias Studio but I am not really familiar with it. I only know the basics of it so I don't know anything broader than it. I came across an OBJ file format and it's my first encounter with it. Can you tell me more about OBJ Alias studio and what it can support? I may find this useful in the future. Thanks!
- 78 reads
- 1 comment
Hi. I heard about Ad Manager Plus 5 during a discussion in class. As I was curious of what this is, I searched about it on the Internet and came across its manual. As I was reading the introduction, it says about managing the "Active Directory". Okay, it is something not familiar for me so if you could please comment below what this Ad Manager is in layman's term for me to easily grasp the correct definition of it. Thanks!
- 52 reads
- 1 comment
