The pipe state is invalid Error when turning on AVG Anti Virus
The pipe state is invalid.
I keep getting the same error every time I try to turn on my AVG Anti virus and whenever I try to download any software. I found out that this error is also present when I open control panel, msconfig, etc. I don't think that this is just an easy problem, considering that most of my window based programs are not running properly even if I made a series of recovery. A forum is stating that this pipe is acting like a connector between two applications. So maybe there is a root application where this started.
I uninstalled the AVG then re install it back since it does not change anything, and also this anti virus is already installed prior to when this message appears. Hence, if it has something to do with AVG, the error would have shown much earlier. I want to determine which service or application is the error associated with. The error also makes my computer to act slowly. I am running Windows Vista Home Premium Service Pack 2.
I also tried booting in safe mode, but I still have no luck.
If you know how to fix this please let me know.
