Minimum USB port on Toshiba laptop
I have Toshiba laptop, the type is satellite E105-1402. I have problem with the USB port. It only has two ports, which i need more than that. So i try to buy USB hub. BUt unfortunately there are many device that sometimes did not support, like USB modem, cable data. And if i plug my external hard drive, i get the notification that my device can perform faster.
How can i handle with this minimum USB port?
Thanks
