I want to edit my free face man template.
Hi guys,
I want to edit my free face man template. What is the best editing software application that will let me edit a free face man sample downloaded from the internet? The free template is just a basis or reference that will help me create my own face man edited picture.
Expecting some help, thank you.
Best Answer by Sharod Enrique
Answered By 0 points N/A #173322
Hi Virginia Adams,
You asked for good software for editing free face man template. There are so many of that kind of software. But I suggest you "Free Filter Xpress". Because it is easy to use and the quality of the work is good. I am giving you a link you can find here the software and the video tutorial of how to use it.
1. http://facefilter-xpress.software.informer.com/
2. http://3d2f.com/tags/face/photo/editor/
Search the sites to get it. I think your problem will be solved
I am glad to help you.
Answered By 0 points N/A #173323
Try the consecrated solution Adobe Photoshop, one of the best programs for graphics. Although it is expensive, the results are spectacular if you learn to use it.
Some open source programs may also do a good job and they will also save you a lot of money, which is important.
To name only a few of them, maybe the best known, try GIMP (GNU image manipulation program), Krita or Paint.NET.
