Is there any way to disable the bubbles of information that appear or pop out everytime there is an updated or a change in settings or any system changes? I find them annoying and sometimes the messages are the same and they get on the way of my work. I’ve tried unchecking the check boxes in aid options tips, but it doesn’t help, it seems to have no effect. Does anyone have an idea on how to resolve this?Thanks.
How to Disable Information Bubble that Appears on screen
There are some pop up messages that can be disabled while others cannot because they are supposed to monitor the actions that you carry on the system for security purposes.
A pop message like the one for the user access control, which when you want to open an application, run a setup, delete a file on the system asks you to confirm that action can be disabled as follows:
Click start on your computer and the type 'user access control' without quotes in the search box.
Press Enter to open user access control window.
Choose the account for which you want to disable the user access control option, and then disable it.
The computer will restart for changes to take effect.
-Experttechyv
