Explanation And Significance Of Event ID 1309 Event Code 3005
Consider a certain possibility of you working on a complex as well as important operation on the CRM web application with great time vale and guess what it’s taking forever.Suks right? Folks while you run a Microsoft ASP.NET Web application you are likely to get a lengthy error which describes the above with a system code name .so what exactly is event id 1309 event code 3005
Answered By 5 points N/A #113144
The reason is a conflict of execution time.The execution time required by CRM web application connecting with your remote SQL Server is exceeding the currently set ASP.NET request execution timeout value. The default set value is 300 seconds. The problem can be solved by changing the request execution timeout by following these steps.
Step 1:On your system where Microsoft Dynamics CRM Server application is installed, startIIS (Internet Information Services) Manager.
Step 2: Expanding the folder Web Sites, right click the Microsoft Dynamics CRM Web site, and then right click and select Properties.
Step 3: On the Microsoft Dynamics CRM Web site properties page, click ASP.NET, and then click Edit Configuration.
Step 4: On the application tab select request execution timeout box and change as per your necessity.
Step 5: Finish and press OK twice
