Cannot connect my bluetooth headset with my phone
The world is moving with the modern technologies. We used wire headset to hear songs and talk with somebody. It creates many problems and often does not go with our status. So, the modern technologies has given a wonderful gift and that is the wireless headset. It is connected with Bluetooth of your mobile. Mobile's Bluetooth helps you to connect with the headset. The cause of your problem might be because your Bluetooth device has limited connectivity. or check that your mobile's or headset's Bluetooth headset is perfect or not. If it had some disturb then repair it. You can restore factories of your mobile or restore the softwares. I think your headset will connect through this work.
If you are having a hard time pairing your Bluetooth headset with your mobile phone, here is a guide that will help you accomplish this.
If you want to see a video tutorial of the whole process, see Pairing Cell Phone with Bluetooth Headset.
