My SQL Server Setup failure
When I tried to install SQL Server 2008 R2 over SQL Server 2011 Denali, it showed the following error message. I would be pleased if someone could provide me with a feasible solution to this problem.
Error:
SQL Server Setup has encountered the following error: Method not found: 'Boolean Microsoft.SqlServer.Configuration.MsExtension.MsExtensionMetadata.get_1sSlpstreamOrPatch
