GPU-Z halts and shows OpenCL driver bug detected
I recently installed a new copy of windows on my PC. I also deployed the AMD 13.1 Catalyst Display Driver and the GPU-Z system utility on my computer but on running it, the GPU-Z opens successfully but I get a prompt with a message as indicated below. I have tried to update the drivers but the message still persists. What could be the problem?
Regards.
GPU-ZATI
OpenCL driver bug detected, skipping OpenCL detection. Uninstall the AMD Stream SDK/OpenCL driver to re-enable this functionality.
