What Is Microsoft SQL Server 2014 Express And What Is Its Importance?
I want to learn database management and want to try it on Microsoft SQL Server 2014 Express. But I am unable to use it and what are the files that I will have to use in it and the importance of this SQL server. Please help me out guys. Thank you in advance
Answered By 0 points N/A #298209
Microsoft SQL Server 2014 Express is free and ideal software which is must to have in order to learn, develop, powering up the desktop , web and small server applications. This software is powerful and reliable free data management system which helps to store lightweight websites and desktop applications.
Various Files used in it and its importance are as follows:
  1. LocalDB (SqlLocalDB)
LocalDB is a lightweight rendition of Express that has all its programmable components, yet it keeps running in client mode. It has a quick, zero-arrangement establishment and a short rundown of pre-requirements. You can utilize it to make and work with databases using code. It is also used with Application and Database Development apparatuses like Visual Studio. You will see two documents one for the 32-bit framework (ENU\x86\SqlLocalDB.msi) and other for the 64-bit framework (ENU\x64\SqlLocalDB.msi).
  1. Express (SQLEXPR)
This bundle incorporates the SQL Server database motor as it were. It is available to acknowledge remote associations or oversee them remotely. You will see two documents one for the 32-bit framework (SQLEXPR_x86_ENU.exe) and for the 64-bit framework (SQLEXPR_x64_ENU.ex  )
  1. Express with Tools (SQLEXPRWT)
This bundle contains everything expected to introduce and arrange SQL Server which can be used as a database server and implementing full form of SQL Server 2014 Management Studio. You will see two records one for 64-bit framework (SQLEXPRWT_x64_ENU.exe) and other for 32-bit framework (SQLEXPRWT_x86_ENU.exe).
  1. SQL Server Management Studio Express (SQLManagementStudio)
This bundle contains the apparatuses to oversee SQL Server examples, including LocalDB, SQL Express, SQL Azure, the full form of SQL Server 2014 Management Studio.
You will see two documents one for the 32-bit framework (SQLManagementStudio_x86_ENU.exe) and one would be for the 64-bit framework (SQLManagementStudio_x64_ENU)
