AutoCAD Architecture 2012 Error 1327
Hello Teac Savvy,
When I try to install AutoCAD 2012 latest version in Windows 7 64-bit operating system, I ended up with an error message and it stopped the installation. How do I continue with the installation? I tried to reinstall in several times but nothing seems to work. Really, I am in help. Please assist me solve this problem. Thanks in advance.
AutoCAD Warning
The following shortcuts in the search were invalid and ignored:
SAutodeskFSE – Acad Standards & TemplatesPlot StylesAdd-A-Plot Style Table Wizard.lnk
OK
Answered By 0 points N/A #188504
This error is caused by an Invalid drive. In this case, it is the drive S:. To solve this problem, you could :
1. Run the command prompt as an Administrator. Press Start, All Programs, Accessories, and right click on command prompt.
2. In the Prompt, type in:
SUBST S: C:Temp
This line sets the imaginary or invalid drive S: to the C:Temp folder. If folder Is not present, Just create a folder there inside the Drive C: and name it Temp
3. Run the installer
4. If installing is complete, you could then delete the substitute directory. Use:
SUBST S: /d
on the prompt.
This should fix the problem.
Answered By 590495 points N/A #323736
If you cannot install AutoCAD on your computer, you are probably using a non-admin account. Though a non-admin account can sometimes install applications, programs like AutoCAD, Microsoft Office, CCleaner, and some other programs that require global modification to the system needs an administrator account. This protects the system from unauthorized modification. If you need to install AutoCAD, log in to the computer with an administrator account.
If you don’t have an admin account, ask someone with an admin account or the administrator of the computer to install the program for you. Also, before installing AutoCAD 2012, check that your computer meets the requirements.
Autodesk AutoCAD 2012 supports Windows XP (Home or Professional edition) Service Pack 3, Windows Vista (Enterprise, Business, Ultimate, or Home Premium edition) Service Pack 2, and Windows 7 (Enterprise, Ultimate, Professional, or Home Premium edition). It requires 1.6 GHz Intel Pentium 4 or equivalent Dual-Core AMD Athlon or faster processor with SSE2 support, 1 GB RAM, 1.4 GB free space, and 1024 x 768 minimum screen resolution.
If you’ll be installing from a CD or DVD disc, an optical drive is needed for the installation.
