Archive
Sony has unveiled a hardware which can detect the complications that are on the skin and it is said that it also detects the problems that may be seen in the future. What are the features in the latest Cosmetic Hardware by Sony? How do these hardware work? Are they worth getting? Clarification needed...
Read more
I'm looking for a systematic substitution  for the video-player, so if I stream the video in Internet Explorer, the substitution opens up and lets me navigate a video like it was done way back in the past(times of SymbianOS).
Can someone tell me if there is a solution for this?
Is this possible to be developed for WP8?
Read more
What is the life-circle of an issue and exception report. I've been looking at some reports, and it looks like each sheet needs to filled out once. Sure, it might not be filled out completely at the exact same time, but I'm not sure what 'life-circle' means in this particular content.
Thanks, in advance,  for the answers.
Read more
The Play Station Camera is said to support the Playroom Games but is it worth getting the PSC. I think that getting one more Dual Shock Controller and playing FIFA 15 with my mate can be a good idea but... What are the features that are available in the Play Station Camera? Will it be able to top the sales of Microsoft Hololens and Oculus VR?
Read more
I have an Action class, where an Action can do a some things like performing a list of differen actions, performing an action where a condition is true and enabling the user to choose among several other actions.
The last situation mentioned is the problematic one.  I need some way to tell the User Interface "offer the user a choice". There are two different thing aI thought about:
  1. To have the action() function to set variables in the UI and return it.
  2. To Have the Action class where a getNextActions() function returns a List of possible actions. If...
    Read more
Few days ago, I bought a HP Deskjet Printer and it didn't have any complications until I came up with changing its cartridge. I had been printing a survey which contained both which and grey blocks. I have changed the cartridge and now, grey box seems to be white. Quality of Printing is also decreased. What can be done to fix this?
Read more
I downloaded the .iso file of Zorin OS 8 from the home page of the OS. After that, I burned the files to a blank DVD using Windows Disc Image Burner. But when I try to boot Zorin OS from DVD then a black screen appears which reads Kernal Panic 0000008.X and else. What can I do to fix this?
Read more
I have installed many applications that should've recorded voice and simply save it to the ringtone folder but none of them seemed to work. I have tried to copy the recorded audio into the ringtones folder, thtough my laptop, and they still are not vidible as ringtones on my phone. I'm sure that those files aren't drm protected. Also, they are under 1MB big. Can someone help me what to do?
Read more
I downloaded the .iso of Far Cry 4 which was around 12GB. I'm able to mount the CD Image using Daemon Tools Lite but when I click on setup.exe, it says that the source file is corrupted. Is it the problem with the Mounting Software or anything else? Have I spent time downloading 12GB of data?
Read more
I heard that NFC tags can help to change the behaviour of your mobile phone when tapped on it. I know that the mobile phone being used must be NFC enable but what else is required to program the tags. Can tags be put to other uses? Also, to what extend does the tag affect the behaviour of the mobile phone?
Read more
