Archive
I'm looking to write a Python GUI that shows: a list of checkboxes, a graph (of the checkbox data).
Which Python library would be good for that (looking for simplicity, free of charge, basic requirements)? The main requirement is that user can modify the parts of the graph in any way he wants to.
Read moreRecently I started to have bad dreams and I'm looking for an app/device that: can measure brain activity / store data in an app / can be bought for a reasonable price.
I searched for it, but haven't found anything which meets my criteria.
I'd be happy if it can be used with iPhone.
Read moreFrom time to time, we find ourselves loading a long webpage and at the same time, we want to screenshoot it. It is difficult to screenshot since it is a large page and need to screenshot multiple times and later merge them to one single image.
So, is there a special web browser or a toola that allows to screen shot a single long webpage into a image file and have the option to control the quality of the image?
Read moreThere are many add-ons available toady but it has become difficult to choose between the available extensions. I know about GD Anywhere extension by Game-Debate but I want some more extensions for my browser which will enhance my experience while searching about the latest games. What are the must have extensions for die-hard gamers which will make their work easy? Any suggestions for me?
Read moreI think that cinelerra is the best free video-editing open-source software available. It is complicated but it has very nice tools. The problem is that I have to load mpeg4 files but it never happens. It works fine on other formats. I've tried to convert mpeg4 to other formats but its quality just doesn't satisfies me. Can someone help me how to tweak/fix it?
Read moreI have VA1912 LED Monitor(19 inch) by Viewsonic and I'm using Geforce 210 as the display output unit. I have overclocked it to 600MHz and when I change the screen resolution to 1154*864 in games then I only get around 40% of the game screen. If I store the clock settings to normal, the problem disappears. I want to run games properly by overclocking my GPU. Any suggestions???
Read more
I'm learning web-automation, currently just using iTerm, Watir and SublimeText, but I thought it's better to use IDE to continue my work.
What I've learned already:
- basics of Ruby
- basics of Watir and Mechanize
Now I need one good IDE to check my scripts for possible errors.
I've tried RubyMine but I'm also looking for other options(with tutorials online if possible).
Read moreI've installed Windows 8.1 on my system. My system meets all the specs of Windows 8.1 but the OS lags badly on my PC. It is the 64-bit version. Windows 7 ran fine on the PC but the latest one is lagging hard. Is it the configuration issue or it's the time for me to buy a new PC?
Read moreYesterday I took my pendrive to work so as to transfer some documents. When I plugged it in my work pc, everything transferred fine and i got no errors whatsoever. I got back home and when I plugged it back it, all my files were now shortcuts. When I check the space used, it still the same but I cannot access any file. Can anyone help me please?
Read moreI want to create a SOA with Django.
I am trying to understand what the result would come up if I choosed to separate and insulate models into apps, to provide the REST API for accessing those apps and after that to create other apps which basically use the REST API to use data and perform operations on the models (DB).
- Which other useful Django features would I lose?
- Is there a work-around through this without exposing the models to other Apps?
