Archive
A serious problem is eating me up. I did some memory stick upgrade on my PC just today. After that when I boot the computer, it starts for some few seconds then crashes into a BLUE SCREEN. This happens repeatedly after ever boot attempt and is scaring me off. Below are a couple of files that can help in describing the problem.
C:Windowsminidump32311-25802-01. dmp
C:Usersbuddyappdatalocaltempwer -53991-0. sysdata.xml
Initially tried installing four sticks of RAM but the system would crash to a blue screen during Windows 7 installer. I then removed two of the sticks and tried booting. This time round it...
Read more
Hello everyone,
Can anyone help ?
I can say I am very upset with Miranda in the last few weeks. The problem commences, whenever I launch Miranda. The ICQ protocol just backfires ; it keeps connecting forever and sometimes it does not connect at all.
I have tried to research and this is all I have got.
- Give it “offline “status manually
-Wait for the error the error message to appear
-Click on the online status once it is connected.
But this is not helping me. I have tweaked all the...
I have recently installed a Netgear WG311 PCI Wireless Card. I am now receiving the error below.
Diagnostic Report (1.9.0019.0):
WGA Data-->
Validation Status: Blocked VLK
Validation Code: 3
Cached Validation Code: N/A
Windows Product Key: *****-*****-2WFBW-Y42XW-9WDKY
Windows Product Key Hash: NPuBAxB/FQRNVyFxbxRQxYjf+Eg=
Windows Product ID: 55274-640-4312605-23246
Windows Product ID Type: 1
Windows License Type: Volume
Windows OS version: 5.1.2600.2.00010100.3.0.pro
Is Admin: Yes
TestCab: 0x0
WGA Version: Registered, 1.9.42.0
Signed By: Microsoft
Product Name: N/A
Architecture: N/A
Build lab: N/A
TTS Error: N/A
Validation Diagnostic: 025D1FF3-230-1
Resolution Status: N/A
WgaER Data-->
ThreatID(s): N/A
Version:...
I have just installed a Windows 7 ultimate. The installation was successful. But a problem came in when I pulled out the Windows 7 DVD out of the drive and carried out reboot. A few seconds during the boot process a black screen with the message BOOTMGR is missing press ctrl+alt+del to restart.
I tried a number of times to press Ctrl+Alt+Del hoping that it will boot but nothing was happening. I checked the BIOS and the windows installation drive was in the boot priority, which it was. I tried pressing F7, F8 and tried to follow the instructions. I have also tried to carry out recovery from a...
Read moreI'm having this kind of problem, that if I open my working website there is a warning that the website uses a code that is enabled. So I went to options > advanced > encryption and I saw there that both ssl and tl are enabled. I can even open the website in my latest IE version and it works fine, and can open the site in an older version of Mozilla. What makes it so difference?
And my second issue is whenever I opened MF, I got a message "A script on this page may be busy, or it...
Read moreHello there,
My name is Alexander and I got some problems. I bought a new Windows Vista laptop two weeks ago. I was so excited that I finally bought it. I pick it up from the store and put it in my apartment. Then I was so happy finally opening it. But when I did open it, I found out, my laptop won't turn on. I was so afraid. I just bought it and it was broken already!
I got really cranky and started to go insane. Till when I tried turning it on again pressing the button of the laptop, it shows me a white screen. The whole screen...
Read more
I am using Windows seven ultimate. I have seen and option in my LAN setting that about sharing the CD or DVD drive through LAN.
But I have never tried it and I don't know exactly how doing it. So I am a bit confused about its reality. I have a DVD-Writer and if I want to share this than what I have to do.
Another thing can I use others CD or DVD drive which is shared? If it is possible then please tell me about the process.
How to do it? It will be really helpful for me if you tell me what to from the beginning.
A detail...
Well I have a DVD drive which is capable of writing. Its model is Samsung 16X. DVD drive and Writer. It sometimes does not open when I pressed the eject button or when I command it to eject from the system. And more over, sometimes it can't read the DVD, though I give it almost a new DVD to play. It only makes sounds but does not show anything in the screen. And another thing, sometimes it can read DVD but can't copy the files in the DVD.
I want to know what is the probable cause of these problems. Why does...
Read moreHey guys,
The make of my PC is dell desktop. I have been using this computer for a while until recently it started developing some complications while booting. Sometimes it produces a funny sound around the motherboard but it doesn’t display anything. The fans are working and their some lighting in the motherboard.
The button used for switching on the CPU sometimes doesn’t work you press it and it doesn’t switch on as expected and normally when I press it once it switches on. Normally whenever it refuses to switch on I power it off and open the CPU and I perform...
Read more
