I installed Zoner Photo Studio 15 on my Win 7 Operating System and working on a project to edit images but today I tried to use this software I got this annoying error message which shows the error in the plugin. I reinstalled the program but the problem exists. What should I do now to solve this issue? Any idea would be greatly appreciated. Thanks in advance.
An unexpected error occurred in the plugin.
Zoner Photo Studio 15 error occurred
Hi Zachary,
You can try to run the software after rebooting your machine in safe mode where plugins are disabled. If this does not work, you will need to reinstall the Zoner Photo Studio after making sure you have the latest version. Also, it is a good idea to keep your operating system updated before the reinstall.
It seems like you got this error from corruption of your program’s files and registries. To solve this, perhaps you should try to reinstall your Zoner Photo Studio. You can use Revo Uninstaller Pro; it will help you to remove all the data and registries completely. Then, run your anti malware software. This will help you to detect some malwares and virus that could be the other reason of error occurrence. If you don’t have an anti-malware you could download it here. After that you might also download the latest version of Zoner Photo Studio to their site. Before installation, make sure to turn off your anti-virus and firewall. Sometimes anti-viruses block some file/data which prevents the program to install.
I hope this will help you to solve your problem.
Martine Paul
Hi
It seems like your Zoner Photo Studio has got error starting the application. Anyway, go this Techyv post  to get more helpful information regarding on this issue.
Zoner Photo Studio 15 Error
