XP welcome screen comes and stuck
My machine has Windows XP.
The welcome screen, i.e.. the black screen comes but the blue bars goes on forever and its stuck.
Best Answer by Tunacao_Caaron1
Answered By 80 points N/A #109989
Screen freezing upon start up or on windows logo could sometimes be because of some external hard drive or flash drive that doesn’t have an Operating System that might have been attached to the computer upon turning the system on. You can try the following to resolve the issue:
  1. Turn off your computer
  2. Unplug all external devices or peripherals such as flash drives, and/or external hard drives
  3. Turn on your computer
  4. Once the computer has booted up successfully, then plug back in your external storage device
Remember that every time you start your system, there shouldn’t be any external storage device attached to the computer to avoid screen freezing.
Answered By 20 points N/A #109990
Here are the fix steps:
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and
