No of visitors who read this post: 439
Category: Windows 7
Type: Question
Author: David allen
No votes yet
Hi. I just want to ask what an XML is? What is its function and why is it affecting my Football Manager. When loading my Football Manager, I always got a "Invalid Token XML Parsing Error". I am running it on my Windows 7 PC. How can I fix it? Kindly please help me. Thanks.
Comment viewing options
# (Solution Accepted)
To fix this issue on Windows 7 PC, delete the FM 2012 Settings folder on the following path:
C:\Users\Username\AppData\Roaming\Sports Interactive\Football Manager 2012\Settings
If you cannot find the Settings folder, please make sure that you have enabled the hidden folders by clicking on Start>Control Panel>Folder Options>View>Show hidden files and folders. After deleting the settings folder, restart your computer and then try to launch it again. And then try to search your saved game files manually on your directory.
Or you can also download and install MSXML newer version from the Microsoft website. If it still doesn't work, try to create a new user account in Windows or load another user account and then start your FM 2012 and select Load game. Select the location C:\Users\Other Profile\Documents\Sports Interactive\Football Manager 2012\games.
I hope you can fix this issue with my solution.
Cathy Emrald
