Tried to generate a report page with Corel Draw on the installation error, Beam * this * error;
COREL
Your case has been created!
Case creation fails.
Why did this error take place (produced be)? If you have ideas, please give me as soon as possible.
An X5 installation failure occurred
Hello My Dear Friend,
I also had this problem, so I did some serious research to find a solution. I found two ways to resolve this issue.
The first way: you must upgrade your X5 into X6 and obtain a valid product key.
The second way: you need to go to Corel’s official website and use their online customer support.
I Know they will help you because someone from customer support helped me with this same problem.
Also, check this website for further guidance.
Hope this will help you.
Good Luck!
