Does datacard like tata photon work on a USB enabled Honeycomb tablet like Acer Iconia Tab? Is Media Recorder built in with Android API useful in capturing voice on Android device?
Working of datacard like tata photon on a USB enabled Honeycomb tablet
Hi there,
Android devices have that kind of ability to configure and connect with media recorder. So yes media recorder can built in with Android API useful in capturing voice on Android device. But you need a little configuration first. You can see these configurations in your manual which is given with Android devices.
Datacard like tata photon is comfortable with USB. So it can be connected and configured with USB. Most important thing is to create interface between datacard like tata photon and USB. There is nothing special that you need to do. It is a simple matter to reconfigure it.
