Hi ! I am a newbie here and I am not computer savvy. I have several computers (around 8 computers running wireless and 2 wired computers) I am wondering why one of my computers is connected but is not able to get online. All the wireless devices I have are working fine. I am just having difficulties going online with my Windows XP computer which is wired to my box.
Please answer. I really need help immediately!
Thanks,
Mitchelle Edwards
You first need to secure your ethernet connection between your router and computer. If it is secured and it still gives you a problem, try connecting the cord to a different LAN port at the back of the router. If still the same, try a different ethernet cord. If the cord is working fine, check if your browser has proxy enabled. If it is, disable the proxy settings by clicking start, control panel, internet options, connections tab, LAN settings, and remove the check from Use a proxy server. If its not using a proxy server, try opening your command prompt. Click start, run, enter 'cmd' and hit OK. On the black DOS prompt window, type 'ping www.google.com'. This will test the connection of your computer to the internet. If it returned all packets sent, it means that there is internet connection. So it could be a browser problem that we are having. If that is the case, you can reset your browser to factory default settings. Click start, control panel, internet options, advanced tab, and click reset. This should resolve it.
Note: You have to powercycle, or restart the router by turning it off, then turning it back on after at least 30 seconds. You can do this by disconnecting and reconnecting its power plug. You can also try to restart your hardwired computer. Doing these first usually does the trick.
