No of visitors who read this post: 302
Category: Windows Vista
Type: Question
Author: Billy3
No votes yet
Hi All,
I’ve been playing music in our office most of the time using media player in a PC which has Windows Vista and suddenly its stop working I don’t really know what’s the cause of this problem. I tried to configure the said message pop up in my screen and just click the ok button for switching to analog mode but same problem occurred. I’d also tried my other mp3 songs in different kind of CD but nothing happens. Any suggestions would be greatly appreciated with this matter. Thanks!
This is the message appear in my screen.
ANd9GcSlv_0I5nogkULBufXBdgYt9Uk5s-XuDXsrpI35mgBh1IcAPZjwywnxvC9B
Windows Media Player Performance
Windows Media Player encountered an error when reading the CD-ROM drive in digital mode. Click OK to switch to analog mode. Click cancel to retry playing in digital mode
Comment viewing options
# (Solution Accepted)
   Hello, go to the following website and follow the steps, you will get the solution easily:
http://www.nwlink.com/~zachd/pss/pss.html#0xc00d11f8
   Best of Luck
Hallo Billy3,
It may be possible that your windows media player has crushed, or maybe the CDs that you are using have a problem. To check this out, I will suggest that you install another player, for instance the vlc media player and then try playing the music or videos on the CD using it. In case it works well, then the problem is with the windows media player.
It may have gotten corrupt due to some action that you took, and therefore you will need to run the repair tool to fix it. Or you can switch to another media player, and if you are for that idea I will recommend vlc player for it supports a wide range of audio and video files.
Hope this helps.
__
Regards
Lee Hung
