Windows Media Player has encountered a Error?
Do get the error message ' Windows Media Player has encountered a problem?
The transfer syntax is not supported by the RPC server (0×800706c2)
System Protection
There was an unexpected error in the property page:
Please close the property page and try again.
Please help me to resolve this error easily …
Answered By 0 points N/A #198971
This error may be caused by virus infections or if the system’s registry files contain errors. You can solve this by using an anti virus to run a full system scan so as to eliminate the virus infections causing this error then update the software your computer. This problem can also be fixed using some of the well known repair tools. You can try the following tools; perfect FIX, registry Easy or Perfect optimizer to repair your computer. I hope this helps.
