Windows 7 Disk Defragmention process not working properly.
When I load the Task Scheduler and error message appears out of nowhere.
Task Scheduler
The remote computer was not found
It seems to me that the computer wasn’t detected.
Please help solve this problem real soon guys…
Answered By 5 points N/A #173358
Dear Frankilin E Bardsley
You need to update your registry settings to disappear the error Message.
To open the Registry Setting follow this steps :
Click Start
Click Run
Type regedit
Click OK.
Now Registry Editor Window opens in left panel.
Go to Computer->HKEY_LOCAL_MACHINE -> SYSTEM ->CurrentControlSet -> services.
Then try to find out "Schedule" . If this exists then change start value to 3 from the right panel.
if schedule is not exist download the attach registry file and then click to import it in your computer.
Finally reboot the computer .
Hope this will help you
