No of visitors who read this post: 525
Type: Question
No votes yet
Hi Friends I need your help, I am work as Movie Mixer, Also I know there are many elegant tools available for this purpose but some time I need movie maker for simple work. But from previous week I am trying to open this software but It generates error for me all error detail is given below. Please tell me how can i remove this error?
RegSvr32
The module “quartz.dll” was loaded but the call to DLLRegistewrServer failed with error code 0X80070005.
For more information about this problem, search online using the error code as a search term.
        OK
Comment viewing options
Hello Unnikrishnan3500,
              I have a idea for your problem. I hope this could help you about your problem.There are many ways to solve your problem. Try to re-install the software of your movie maker using higher or lower version of movie maker u have. Download another movie maker if you want. Better try to explore another movie maker like adobe After effects" or "Windows Movie maker". Find another movie maker that suitable for your windows operating system. Turn off your Antivirus before you download the software, the software might corrupt if there is a virus on the software you download. Turn back on your antivirus after downloading and installing the movie maker. And scan your computer to prevent viruses encountered from your computer. Done!
Hope you enjoy exploring.
Thank you.
Good luck!
