Winamp error while trying to open audio files
Hi there,
I want to play a recorded file by me and I want to open it with WINAMP player. This is the error that I have and the recorded file is saved as .mp3. I can play all my songs with WINAMP and this is the only one. Does anyone have any idea about this error? How can I solve it ?
Thanks !
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaa – aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
The instruction at “0x0060a30b” referenced memory at “0x61a74e65”. The memory could not be “written”.
Click on OK to terminate the program
Click on CANCEL to debug the program
OK Cancel
Answered By points N/A #178240
Such issue indicates problem either with your OS or your software that have got some corruption inside it. In order to fix this issue,
1. Start Command Prompt, run “sfc /scannow” command.
2. Restart your PC and try to open the file again.
3. Download the latest Winmp. Uninstall the older one and install the latest version.
Also, you might also need to clear your PC. In such case, use CCleaner. It is powerful, easy and efficient. Download CCleaner.
Check the recorded file whether it is written properly or have corrupted data. If the data is corrupted, the player will be unable to load it to its required method and throw up such error. Your MP3 file can be fixed using MP3 Diags. Download MP3 Diags.
