Everytime I type in the 192.168.1.1 address, I get a message "Internet Explorer Cannot Display Webpage". I have frustrated this several times, then it doesn't connect me to the website. I am surprised if Saga Lout worried to check to see if he or she can connect to the site before giving info that doesn't seem to address the real problem. Personally, I really object to comments like, "you're not typing in the right address
Why i can t access 192 168 1 1
It's not a website – it is truly the address of a router which forms the hub of a local network and occasionally handles the Internet connection as well. Unhappily though, it isn't yours or, so long as the cable is connected from the PC to the router, entering that in your browser would gross you there. So, you either aren't wired up properly or it's not the exact address.
If you're only consuming wireless to get to the router, you aren't connected correctly and it's probably because you haven't got as far as planting in the router security key. Use the information in this link to our Sticky Post on this matter to find the right address then usage the cable that came with the router to connect to it. For more info click here
It's not a website – it is truly the address of a TP-Link router which forms the hub of a local network and occasionally handles the Network connection as well. Unhappily though, it isn't yours or, so long as the cable is connected from the PC to the router, entering that in your browser would gross you there. So, you either aren't wired up properly or it's not the exact address.
