Hi Experts,
I am having ms word 2007 and I am getting message please install at atleast one language when I checking langauge options tab.Can anyone tell me why I am getting this?My default language is US-English.I did not change the language settings.Thanks.
Adolfojeremiah
Follow these steps to set your language in Microsoft Word:
Best regards,
Heather marie
Hi Adolfojeremiah,
It is possible that you have not installed the Language pack for your Microsoft Word. All software comes with a default language, so clicking that option informs you that your software does not have the capability to detect or be used for other language than US English. The Language pack can be used if you want to write using a different language so the spell check and formatting will also be enabled. You can set it to change automatically or highlight then change it to another language. If you want to experiment on this you can download the Language pack here.
