Why don’t i have access to Skype conference server?
Hi, I have one big problem, I cannot access Skype conference server, so if someone had the same problem, please tell me how to solve it, I need conference right now. What is the problem here, my configuration or something else?
Best Answer by Hanthy moshu
Answered By 0 points N/A #164610
The Reason Why you can't connect to the Skype Conference may be you have a low connection or the person/the group you're trying to invite has a connection problem or maybe you're not using the latest version of Skype which is Skype 5.0. Close any of application that might be a video.
Make sure that your computer meets the minimum style requirements to run Skype and it's not on compatible mode. If you're still having the same problems try to uninstall and install again the Skype and follow that what is written above. Hope this can help.
Answered By 0 points N/A #164611
Hello!
You might not use the updated Skype Version. I had also experienced this situation thus I highly recommend that you should update your Skype to the latest version in order for you to have a conference call. Get your updated Version of Skype here https://www.skype.com/en/ . Hope it will help you.
Thank You and God Bless.
