Why do not install 3D Max in my PC?
I have a DVD disc of 3D Max software. But when I install it for my OS then it shown by a message like this ‘Internet connection is needed to install’. When I connect internet it has been long time to installing. But not install. Now what can I do.
Best Answer by alexx
Answered By 5 points N/A #84440
Have you checked the installation requirement for 3D max in PC? If don't then check now. Maybe your system is not supporting it. If you see the same problem after this then checks your RAM memory availability from task manager. Try to close all unnecessary programs before installing the 3D max. Because you also know that it is very heavy software and it takes time to load and install.
There can be another reason. Are you installing the registered version of 3D max or an illegal one? I have seen the same problem in the installation of many manipulated software. So try to install a registered one.
Answered By 0 points N/A #84442
Luther ,
Basically internet connection is required by 3D Max for the validating purpose of your Product key. So you must ensure that your internet connection is stable. Before staring installation you must log on to the machine using an administrative account. Ensure that your hardware has met the requirements of Shader Models (Pixel shader and Vertex shader).Visit the following URL for more about hardware support https://support.steampowered.com/kb_article.php?ref=4360-TPJL-2065. Be sure that your system has at least the minimum requirement.
If you used older versions of Backburner uninstall the older version. Close any other background programs including MS outlook, anti-virus programs, Autodesk products and other unwanted software.For more details watch
Answered By 590495 points N/A #306618
I think you are referring to Autodesk 3ds Max. If setup prompts you that internet connection is required to install the contents of the disc, then you should connect your computer to the internet because setup detected that your machine is offline or not connected to the internet.
But if there is no activity even after connecting your computer to the internet, try resetting your router if you are connected to a router. If your router has a power button, turn it off and unplug it from the power for about 10 to 20 seconds. Press any button on the router to drain any leftover power.
After this, plug the router back to the power and turn it on. When the router is ready, open your web browser and visit a website then try clicking some links to see if the connection is working. Once the connection is working, restart the installation of Autodesk 3ds Max then see if it works.
If it doesn’t work, check the system requirements of the application you are installing because you are probably installing it on the wrong operating system.
