I share important files working with my colleagues and always someone deletes them after they copy on their computer, then all those who go after him, find nothing.
and sometimes it's the original documents, so I lose them also.
is there a possibility to find out who deleted a those file from the shared folders?
If you are working on the same computer and you keep things in the shared folders then you can't detect. If that computer has multiple users, then it is impossible to know who did that. But there's one way you can recover that file if it has been deleted or you can recover it even if its not in recycle bin. For that you have to install a software called "recuva". This software is easily available on website for free. Just install it and then open the "recuva" type the exact filename, search on the drive your file was before. Or you can search the whole computer too. It may take some time but its obvious you'll get it.
On the other hand, if you are sharing computer with other computer, then you can detect the other computer. Again multiple computers on the network maybe an obstacle again on detecting the specified person.
SO, my suggestion would be to use "recuva" on the main computer in which the file was use to be.
