White background templates for best expandable websites
Hello, I found articles on how to code expandable sidebars and main pages but it’s going to take some time. My company needs to have at least two homepages and I’m looking for white background templates for best expandable websites. Please suggest or give me links that share free downloadable html templates.
Best Answer by Peter A May
Answered By 10 points N/A #199274
Hello Roman Curtis,
Finding great templates is easy. You can easily create your own templates as well using softwares available for it.
Here I suggest some sites from which you can download templates for free for your websites.
These websites will also teach you regarding this.
https://1stwebdesigner.com/free-responsive-web-templates/
https://speckyboy.com/free-responsive-html5-web-templates/
https://www.quackit.com/html/templates/
Hope this solves your problem.
http://www.zymic.com/free-templates/
Build templates,
https://www.campaignmonitor.com/email-templates/
Thanks,
Answered By 10 points N/A #135504
Hi Roman Curtis,
If you want your background of the website will be white then you can customize any templates. Just change the background in the code. There are many white background templates also but it may be not enough for you. I am giving you some web addresses where you can find out many white and black background templates just download from there. If you choose any black background template just change the background from the code.
http://www.designprefix.com/2012/07/free-html5-website-templates-layout.html
On this website there are  many white background templates. You should choose from there and if you choose any black background it is not a problem, you just customize background color in white.
Why you should visit this website? Because you can get here more white background website from another website.
Good luck
