While sharing a file with WinZip I received an error message
Hi guys,
While sharing a file with WinZip I received an error message. Have a look at the message below. What does it mean? I searched several sites to get a remedy of this issue but no result. Please help me to solve the problem.
WinZip Multiple files were droppec, and one or more is an archive.
WinZip
Add files to archive?
Best Answer by Linknya Jean
Answered By 0 points N/A #190424
Hi Joseph,
Thanks for sharing your problem with us, there could be multiple file with the same name. Please check for the files that you are having for the duplicate name. You can reinstall the winzip and try again if it still not work then I suggest you anther program winzip 7 which is same as winzip, and it is free.
Link for Winzip7 download.
http://www.7-zip.org/download.html
Thanks
Answered By 10 points N/A #190425
You have two files one archive and another that is not archived with the same name and you are trying to zip them within a zip file. Check file name was dropped and remove it from the list and you will be able to zip other files. Also make sure that your computer contains no virus.
Smith Thompson
