Which programming language is used to create Android applications?
Hi guys, I want to know which programming language or script is used to create android applications as I want to learn how android apps are created but I don’t know any thing about it and also to learn how to create android apps I want to learn android development before which I want to learn its program so that it wil be easy for me to learn later.Please answer me thanks
Answered By 0 points N/A #181956
Rex,
Good for you to start learning to program apps in Android.
Here my suggestions, go and download for free in the internet Java for dummies and Android apps for dummies, those books are really easy to understand and will give you a better idea of what the subject is. You need to learn a little Java basis to learn Java for Android apps developing.
You have to download Java SK package from the Java site, download all the package and plug ins needed depending on the current system of your computer. It is easy to install and there are a lot of examples on the site.
Also, download Netbeans, you can do it from the same Java site, this is the software you need to develop and write the apps you want.
Have fun learning
Hope this helps:)
Riley
