Which one to choose between Apple and Microsoft?
60 points
Posted on - 02/17/2015
Apple is probably the best manufacturer of laptops, phones and other hardware. Also Microsoft is good in the above mentioned hardware manufacture. Which is the best manufacturer? Which one should we choose while buying laptops and phones? Is it the MacBook or the Surface PCs? Which one is the best solution?
