Which one is the best private website builder?
I want to build a private web site. So I want to pick a best private website builder. My website will little but informative and will use my stuffs only. So I need to build my website at low cost packages. Is there any builder that is suitable for small private site building?
Answered By 50 points N/A #157809
I guess you are talking about building your personal website.
You can opt online website builder for which you have to be online and login to builder site whenever you want to update. These kind of website builders are mostly available free upto certain storage/bandwidth and they even host your website for free.If you want more storage bandwidth then you have to pay them .They provide really cool templates and are easy to work on.
My personal favorites are
www.wix.com
www.webs.com
www.weebly.com
Since your requirement is simple and small, I recommend you any of those online website builders..
