Which has better battery, Asus Zen Fone 5 or Samsung Galaxy Grand-Prime?
Hello, I was just comparing the features between Asus Zen Fone 5 and Samsung Galaxy Grand-Prime. I would like to know which device provides a better battery backup. Which has better battery, Asus Zen Fone 5 or Samsung Galaxy Grand-Prime? Can anyone share your views about this please?
Best Answer by Monsey talker
Answered By 0 points N/A #200114
The answer to your question which mobile device has better battery backups compared to other devices is as follows.
The Samsung Galaxy Grand-Prime has better battery than Asus ZenFone 5. Samsung Galaxy Grand-Prime has a longer time battery duration than Asus ZenFone 5. Samsung Galaxy Grand-Prime has a battery capacity (mah) is 2600 and Asus ZenFone has 2110. Samsang Glaxy Grand-Prime has a removable battery while Asus ZenFone 5 have not.
Answered By 0 points N/A #200115
I used both mobiles and below is the review.
Galaxy prime went for 2 days of regular use just call a SM.
Where as Aus Zen Fone 5 battery goes for 1.5 days of regular use.
So I will tell you just go for the Galay Prime if you want more battery backup. I am ignoring all the other feature because you want better battery timing so I suggesting you Galaxy Prime.
