Hi, I want to find the best broadband data meter widget for reviews especially for Windows 8. So start posting your replies on the widgets you know that is the best. Doesn't have to be just 1 if you think there's more than 1. The more, the merrier. Thanks!
Which is the best broadband data meter widget for Win 8?
Dear user,
I have done a research for your broadband data meter widget and have found some websites for you from which, you can download your widget. Here is a URL of a website:
https://www.gm2k.net/gadgets/bpusagemeter/
You can also download think broadband meter. It has many nice features. Here is a website URL, from which you can download it:
https://www.thinkbroadband.com/tbbmeter
Hope this will help you.
Thank you.
If you want a bandwidth monitoring tool on your computer to check your bandwidth usage, you can try NetWorx. It is a simple, flexible, and powerful tool that can help you evaluate your bandwidth consumption. You can use it to gather bandwidth usage data and measure the speed of your internet connection and other connections.
The tool allows you to monitor a specific network connection or all your network connections. The latest version at the moment supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. Unfortunately, versions after NetWorx 5.5.5 have been commercialized. They are no longer free unlike NetWorx 5.5.5 and earlier.
NetWorx is now available as a trial version and works full featured for 30 days. Versions for OS X and Linux are also available. For pricing, go to NetWorx Purchasing Information. Prices vary by number of devices.
