Where is the wps button on my linksys router
I am irritating to connect my PSP to my wireless internet other than I require a WPA code or something, pardon, is this and how do I discover out pardon key is?? How do I get in to the arrangement of my router to pronouncement the IP address from my router and in to the secret situation for the wireless?
Answered By 0 points N/A #146300
The problem  is not with your PSP, the problem  is in your router. The WPA key is a password that lets you connect toward the internet Uncertainty you at this instant the password. Uncertainty you don't, then you can't use that one. When you scan for an internet connection and in the middle the situation says NONE you can use the situation. From a command prompt, type ipconfig. Your router address is the Default Gateway. Probably something like 192.168.1.1Type that in toward the address bar of your browser. You will be encouraged for a user name and password. You will need toward getting that from whoever set-up the router. Once you get in to the router you will probably discover that the WPA password  is just a row of in the same way. In which quickly you will necessitate to get that from whoever set-up the router.
