Where to get Wizard icon download for XP
Hello Friends,
I am creating small customized data conversion tools, which I am supplying as packages with installation wizard to my customers, I am in need of a few icons for my tools in windows xp. Please advise on where to get the wizard icon download for XP.
Thanks and Regards,
Emma Marie
Best Answer by Miguel M Burch
Answered By 0 points N/A #189464
To download Wizard icon for Windows XP, try the following link below:
https://usitility.com/download-pc-wizard/windows-10
If you want to create a custom icon for Windows XP, click the link below for instructions:
http://www.aha-soft.com/faq/q5.htm
Answered By 50 points N/A #189465
Greetings Emma! If you are looking for icons for your wizard installer, you could try iconarchive.com. They have tons of icons available for download but you have to give credit to the creators and even check if it is available to be used commercially. You can even try other web sites for there over a lot of them in the internet. Some may even allow you to use their icons for your project's purposes for no cost.
