Where to find the Samsung star touch config?
Hello friends,
Where to find the Samsung star touch config? I need to configure my new Samsung star touch mobile device; I have to change something in the settings. This should be done properly in order to avoid future problems. Can you give me the proper process to change the time and date as well as the wallpapers and alert messages assigned tone?
Thanks and Regards,
Sophiaa Price.
Best Answer by Kevinn Nicholas
Answered By 0 points N/A #165111
Hello Sophiaa Price,
You can set up your configuration manually, just follow these steps:
Go your menu's message options, then go to settings and find the Email Setup Wizard.
Enter your email id: [email protected], Incoming Server type : POP3, Incoming Server: pop.gmail.com, Outgoing Server SMTP: smtp.gmail.com, Secured Connection: Off, then click ok.
Now your POP3 email account should be configured successfully.
Answered By 0 points N/A #165112
Dear Sophiaa;
You can easily change the time and date setting of your Samsung star mobile phone. Simply you have to follow these steps. Open the setting from menu and follow these steps.
  • Time and Date
  • First set the time and slide the screen until date appears.
  • Click and change the date.
For configuration of your wifi, delete all the previous connections.
  • Enable Wifi
  • Open Browser
  • Setting , Profile and Search for wifi
  • Use these connection details.
  • Auth type = WPA
  • Encryption =  WEP
  • General key length = 64 or 128 bits
  • Index ID =1
  • Network Key = **
  • Protocol = HTTP
  • Proxy addresses = blank
  • Normal Linger Time = 300 second
  • Adhoc = off
