Where can I locate Galaxy tab Mac address?
Where can I find my Galaxy Tab MAC address?
Is this in the options menu or do I need a third party app?
I need this for troubleshooting purposes with my DLink router.
I have a 32 GB Samsung P1000 Galaxy Tab with Hummingbird chipset and Android OS 2.3 (Gingerbread).
Best Answer by Mmorriss William
Answered By 0 points N/A #180640
Hi Hugh Egnor,
It will be my pleasure to help you in answering your question which can be done by the following steps:
1. Choose “Menu” from the Home screen.
2. Click on “Setting”
3. Then in “About device” click status
4. Mac address will be on this screen.
Hope this was helpful for you.
Best regards,
Don Muench
Answered By 0 points N/A #180641
Hi Hugh Egnor,
MAC Address (Media Access Control) of Samsung Galaxy Tab can find out in two ways.
The first method is already mentioned by Mr. Don Muench and if you still having some problem to get your MAC address then try the second method.
Do follow the below steps:
1. First of all, on your Home screen tap on Menu button and then on Settings.
2. Now tap on Wireless and Network and then choose WiFi Settings.
3. Tap Menu key and Advanced option.
Here you will get the MAC address of your Galaxy Tab.
