Where can I find working driver Sybase Para Windows 7?
Hi there!
I would like to get driver Sybase Para Windows 7 to install since the one that I have does not install on the platform. I have tried it before on a Mac Operating System and it worked just fine prompting the assumption that it would work as well on Windows 7 professional. How can I tell whether the driver is not Windows 7 compatible or whether it is just corrupted? Thanks.
Answered By 0 points N/A #141646
There are different products of Sybase and I’m not sure what is the exact product you would like to have. So I can only give you the download website of Sybase. You can select the exact product from here.
As an added information before downloading the driver, you should check first your System Type to know if your Windows 7 is a 32-bit or 64-bit Operating System. If you install a driver that is not compatible with your system, you will not be able to use it and it will only fail.
You can find the System Type of your Operating System by going to your My computer properties. You should be able see the sample image below.
I hope this solution have helped you.
Good Luck!
