Where can I find free version ogg player web?
Dear Experts,
I am an initial level of web developer and in search of OGGPlayer to embed in my Website.
Can anyone help me find a free version ogg player web?
Best Answer by Langford Mikee
Answered By 240 points N/A #169158
Good day Erskine, I believe I will be able to help you find a solution to your question of where to find the ogg player for the web.
The ogg player is a really nice media player designed for the Symbian phones or even the on the web in internet. In that it supports most of the codecs required to play a media file.
You can be able to download the software from the website;
From there on, you can follow the prompts to install it to be able to start using it, and it will be functional.
OGG Player
Restart your computer after the installation to make it function perfectly or fully functional.
MP3 converter
I hope this solves your question.
Answered By 0 points N/A #169159
The VideoLAN client player doesn't solely support the OGG multimedia system container, however it additionally supports the Vorbis, Theora and Speex formats, which means that right from installation is ready to play the overwhelming majority of OGG files you'll acquire.
The player directly supports OGG while not the requirement for DirectShow filters or special codecs to be put in.
If you're searching for a fast answer then this often actually it, however if you wish to appear on alternative samples of these players or learn to play with Windows Media Player and store it in your Media Library, then browse on.
Download player with multiple playlists and a light, clean interface. – Softpedia
VLC Media Player VLC Open Files
