Where can I find 360 degree view software?
I have more or less 10 panorama jpeg files of the same subject rotated at fixed intervals.  What I would like to do is, combine them all into 1 file and create a rotating interactive image and save it as a .MOV file.  Where can I find 360 degree view software?
Best Answer by Martin Trish
Answered By 0 points N/A #128057
Hello William
You are looking for 360 degree view software to convert panorama jpeg file . So many sites offer software for this purpose. Some are free and some for free trial of 15 days and 30 days.
Panorama maker is one of the most widely used software to make 360 degree  rotation of jpeg files. This software is available for 15 day trial.
I am pointing to a site which have tutorial to make this. Have a look at it and do all the steps .Surely your work will get easier by using this software.
Thanks
Answered By 0 points N/A #198442
Hello William,
You can also use Dermandar, a free web application. With this you can easily create and share 360 panoramas with fast online freeware and then embed the result in your blog or site. There is no registration, no download or installation needed.
Please visit the site.
I hope this will help you.
